WD-45 Shifter
I recently bought a 1955 WD-45. The shifter was sloppy. Now it will not shift. It acts like it is in gear, but shifter moves freely. When I engage clutch it acts like it wants to go, but stalls out. Last owner said, he had changed out shifter and forks.
Any suggestions !!
If you look at the way the shifter is designed you will probably see the problem.
If you want to see it before you remove yours you can view the breakdown on the Agco Online Parts Books.
Parts Book
It sounds like it is locked in two gears at the same time. You'll need to pull the shifter and reinstall it once you get it out of gear. When the shifter is out, examine for excessive wear. The previous owner may have put in a different shifter that was also worn out. The other suggestions may help you decide what is worn out the most and causes the trouble. I think it will be the ball on the shift handle and the socket for that ball on the tower.
Thank you for the info. I pulled it out and I think you were right about it being stuck in two gears. I freed it up and am trying to reinstall. I can not seem to get it lined up right. The shifter seems to be okay. But it does not fit into anything in the gear box. It just moves around freely.
I had the same problem with my wd45 and replaced the the shifter and trans. top with a complete good used unit .Now it's good and tight and shifts perfect. Someone tried to build it up with weld and made a mess so it was imposible to repair.
Ron, it isn"t easy to reinstall. I"ve never done a WD-45 shifter. I recall that someone felt it was easy to get it back in if you shifted the transmission into first gear and then put the shifter in the correct spot. Good luck. It isn"t an easy job no matter how it is done.
My WD did the same thing. I had a GOOD welder repair and straighten my shifter and it has worked great since then. Take the shifter assembly to a local tractor or auto mechanic and they can probably help you too, It sounds like someone worked on it and it may not be assembled or adjusted it properly. I believe there is a little pin you can get a replacement or oversize for at the bottom of the shifter. Sometimes you can shim some of the play with a washer. The shift cover itself can get worn out too on 45s. This would require replacing the entire shifter assembly.
TD- I find it rather easy to install if I shift the shifter into REVERSE, and move the corresponding gear as well into reverse. Seems that the reverse fork slides around the other gears easier to line up with the slider. I just line up other sliders as I lower the tower.
JMS - I guess I did not do it right. Now the shifter is free. But, I now only have 2nd gear. Does this mean I have to pull it apart again and start over?
Yes- watch carefully as you lower the tower, line up the components. Get the reverse done first, other two as they come down. Install two bolts tight, should be ok to try the shift pattern before tightening everything down.
Been busy on other stuff last 2 weekends. Finally able to get back to tractor yesterday. Still no luck with getting it right. I am assume that the longest fork is reverse. I am not sure on how too know if it is in reverse before install tower. I also wondered if the forks are suppose to move back and forth freely with the round rods they are attached to. They move side to side freely. But, the forks and rods do not move back and forth. I was thinking that this could be my problem.
