WD-45 still stalling out
First, I want to think everyone for their replies to my problem!! But, it did not solve the problem. I drained the gas and put a plastic tube into the top of the sediment bowl assembly and stuck it back on. The tank seemed to be pretty clean for it's age. Also, I found a rock covering half of the outlet hole and a pencil in the bottom of the tank. After I got those out. It seem to start alright and ran longer than before but than again it wanted to stall out. I kept it running by using the choke. I also hit the carburetor like it was suggested and it seem to help a little. I put carburetor cleaner into the carburetor and it did not seem to help. Sometimes when I pulled the throttle wide open it would work okay and then it would stall. A few times when I pulled the throttle wide open it would not do anything. Does anyone out there think that I need to replace the carburetor ? Also, could it be the gas I am using. I have been using Shell with that Nitrogen additive.
It may be air in the sediment bowl. Loosen the glass and let gas get by the gasket and then tighten the bowl back down.
If that does not work I would first blow all the ports in the carburetor out with high pressure air and also check the float setting.
Send me an email for a Zenith and Marvel service manual.
[email protected]
Sounds like you have either a major carb problem of maybe a leak in the intake manifold and your loosing vacuum. Pull the drain plug from the bottom of the carb and make sure you get a good steady flow of gas for at least 5 minutes. Catch the gas so as to look for rust.dirt/water in it. Also with it running take a propane torch and hold it close to the manifold, have the valve on it open but do not light it. If your rpm jump at any time doing that then you have a leak in the intake system
Impossible to have air in the sediment bowl that will cause a problem since if the float opens as it should then no air can be there. Air goes up hill and once the float opens in the carb the air will go up and into the tank and can not stay in the sediment bowl. Only time air will be in it is when you dumped it out and the carb was full of gas and then yes there will be air in it till the float drops
When you first put it back together I have seen them not fill fast because of air pockets.
The air should vent out on it"s own.
When I put it back together the bowl did not fill. I loosen it and it filled back up. No filter in fuel line just above sediment bowl.
That is nothing to worry about. All that tells me is that your carb is full of gas and the float is doing its job. If you leave it alone and you start the engine the sediment bowl will fill the moment the float drops down. So that problem is not a real problem but a metal one or in other words it is all in your head. Works the same way as if you take a soda straw and hold your finger over the end and stick it in a glass of water. Well guess what the straw does not fill but remove your finger and it will. Then if you put your finger back on and pull it out of the water the water will stay in the straw till you remove your finger. All that adds up to is things are working just like they should
Old, the original bowl screens from AC are so fine, air does not readily pass through..
I have always had to loosen the glass and let the air out on my WD-45...
Don't ask me "Why", but my AC will develop a miss, if there is even just ONE lonely drop of water in the sediment bowl..!!
Otherwise it runs fine..just have trouble getting anyone to ride on the front-end, to help keep the front-end Down..!!
Ron.
Well either you have the odd one or I have always been lucky. My WD, WD45 and D-17 always run well even if the sediment bowl if half full of water which does happen in my area because of how humid it always is
Has the gas line been replaced? I had to replace my steel line with copper tubing and flare fittings. If it has rubber hose in the line anywhere I have seen deterioration from ethanol causing problems in the carb.
I am not saying mine "doesent run well", I mean when working HARD I can tell if it ever misses there will be a drop of water in the glass..
Clean it and that miss will disappear...
Where are ya, Old..?? I am in Central Ohio.
Looks like Winter is on it's way back today...!
Hope the ground Freezes before we get much snow or I'm gonna tear things up pushing snow..!
Ron..
I'm in Missouri the Lake of the Ozarks area.
Ya winter seems to be coming back here also. Last week it was up around 60 and boy was it getting muddy. Frost coming out of the ground but down deep it was still there so the top 6 inches or so was full of water and made it hard to get around. I got my small truck stuck a few times and it was all I could do to get my 4X4 one to go where I wanted it. Now this morning it is 32 out and we have snow flurrys
Have you removed the fitting where your gas line connects to the carburetor? Some tractors have a screen behind that fitting that may be plugged with rust or dirt or both restricting the gas flow. Hal
Check you oil bath air filter. One on my IH 140 had some water mixed in with the oil. The water froze in the cold weather effectively stopping up the air intake. This cause really poor operation until I took off the oil bath bowl.
Just a different take some times it is the simple stuff that trips us up. Much cheaper to change the oil than rebuid a carb.
That screen was the biggest trouble problem on those tractors.Old can say what he wants,but there were more service calls(new tractors) made for that screen then any other.The least little water would stop them up in a matter of 5-10 min.
