ROWDY33
In a compression test with all 4 spark plugs removed, is 90 PSI good or what? What is a good compression test? It ranges from 90 to 95. and i know that is good. Not so sur about 90 lbs though
It isn't great and you will be down a bit on power. However, if you are not in competition, it will probably give you years of reliable service. Problems with low compression are starting and plug fowling. If it starts good and the plugs don't fowl, you don't need to rebuild now.
Just out of curiosity...
1. What should compression be on an early and a late model WD?
2. Do you need a complete engine rebuild to fix compression issues?
3. What causes bad compression? Bad seals? Worn engine metal? Stuff wearing out?
Are you sure it's a WD45 and not an 'imposter'; like a WD with'45 decals or a WD45 with a WD engine??
Does it burn oil, and/or is there a lot of 'blowby' from the crankcase breather?
Does it have a miss,smokes a little? If not At 90PSI I would think blowby and rings goeing away but probably not any time real soon and not real bad for an old Engine. If you do not run it to do a job but only for amusement as I suspect, I would get some "Engine Restore",install as OLD says [credit] 40 wt OIL if you can find some or 20/50 if not and the "Engine Restore" and have fun.I've used Engine Restore for many years on old engines and have not been disapointed by the increased Engine life it contributes.
