Hi,
I need some second opinions on gas getting in the air intake of a WD45 carb when starting. If it does not start on the first couple of turns, I have to suck the gas out of the air intake. I’ve been looking at past posts to find possible reasons and have narrowed it down to the float, timing, and stuck valve.
The float seems to be set right because it will not flood by sitting. When I finally get the engine running, it sounds fine so I’m leaning away from timing. As far as I know, the motor has never been rebuilt and was rather dirty when I bought it. There is very good suction at the carb but when I release the ignition I can feel air coming back. Is this common when I release the ignition? I really would hate to pull the head if not needed.
