please tell me your opinion on the following.
Running the dozer in idel, then engageing a lever to stoke a hydraulic function Hyd. oil pours out the bottom of dozer in the front underneath, pulling the inspection cover it appears the Hyd. pump that directly mounts through a spline collar to the out put shaft on the engine is leaking profusely Pulled pump took off registration plate the shaft movement was nill shaft bearing seems very good.
My thought is to replace the oring seal and steel encased shaft lip seal. Pump is std gear pump more or less a 1962.
Is this what you would due outside of installing a retrofit pump
thanks, Don Henry
thanks, Don Henry
