gears
So I'm getting the front pump drive setup on my 3400, adapting a later model 776a loader onto it. The 776 uses a chain coupler at the pump, the 730 (standard equipment for the 3400) uses a moreflex 4 bolt flange adapter. I ordered a chain coupler from SurpCent and a splined sleeve. Turned the sleeve to the 1.125" for the one sprocket. I had considered welding them together but was thinking that the key would suffice.
Opinions? Another option is welding the key into the splined sleeve and allowing the sprocket to slide on and lock in place with the set screw. this coupler is rated at 78 hp so I'm not worried about wearing it out.
