Steve@Advance
Had to load up the wire welder and take it to a job site today.
It's a 15 year old Millermatic 210 MIG welder running .035 steel wire.
Got to the site, unloaded, powered up, went to weld and all it would do was pile up red melted wire worms! Not enough power to strike an arc...
Checked the ground, moved it to a better place. Checked the incoming voltage, 230v. Looked over the obvious for loose connections, cycled the wire speed knob, ran the voltage selector switch through the range and made sure it was clicked in on a number, everything looked good.
Still nothing but red worms...
So I turned the voltage up a notch, same thing, another and another, ended up on 6, higher than I have ever had it. It finally started welding, 10 ga structural with .030 wire.
No way that's right...
It worked that way for a couple welds, then went hot. Turned it down to 3, red worms, back to 4, it worked. Then got too hot again, down to 3, where it has always worked for that material. It stayed on 3 the rest of the afternoon, worked as normal.
I think something may have shook loose inside riding in that rough trailer, drove some rough roads.
Any ideas? I haven't opened it up. I suspect it is filthy inside, it sits next to a band saw that commonly cuts cast iron, and then the grinding dust...
Thanks!
