I have a cheap 110 V Chinese Tool Store welder that I call on occasionally to weld something that should be within it's capabilities (limited as they are). It's a flux cored wire feed type. The welds are of course completely worthless. I might as well use superglue. The welding material can be knocked off with a hammer tap. They look like a collection of splatters rather then a weld.
My question is what is the most likely cause of these crappy welds, me or the equipment? I admit to being a novice, but it seems like this equipment doesn't generate enough heat to fuse the welding material to the work. But maybe I'm doing something wrong? I just want to be sure the problem is not my technique before I shell out $ on a good welder.
