Well there's my problem
Pulled the gas tank off the 410 to see if I could figure out my fuel starvation problem. The fitting leading from the tank to the fuel bowl was completely plugged with rusty gunk. Hopefully after cleaning it and the tank out I won't have to worry too much about it.
Yes thats Why I Hate messing with dormant Gassers When I need them to Get the JOB Done !,, A daily/weekly runner will not have any problems,, but let her set for a year and this is likely to happen.. More often than not , that valve is the Gremlin that starves my gassers out ..What i do is Clean The Valve assembly after completely taking it apart ,SEAFOAMand or LUCAS fuel stabilizer helps ALSO a qt of ATFin 5 gallon or more is a Good Cleaner , you mite put a 1 or 2 inch standpipe on the vale to keep crud out ,, if RUST IS Plentiful ,, Take off the tank and redKote it ,, search Archives for best methods
Roll up some window screen and stuff into the top op the sed. bowl housing.Keeps the rust out and allows fuel to flow thru.
caseman-d
