Wet basement
flying belgian
At one of my rentals the parking lot goes rt to the house foundation. The blacktop flares up just a wee bit but if it rains hard it runs down the foundation and gets the basement wet. I have put bin tar along the seam but as it dries out it cracks and water again comes in.
How should I tackle that? I'm thinking put some metal flashing down and tar that in or perhaps pour a 2 inch cement curb along wall.
Is the layout ripe for a French drain or does the grade make that impractical?
Changing the grade to slope away from the building for a few feet has worked the best for me.
Have you checked with a foundation company or slab jacking company?
Maybe they have something to pump down in deeper an be more permanent
On our barn the tin flashing worked for a long time.
What is the vertical surface you are trying to seal up to, concrete block, or ??
Yea, ours was the wood planks that was the side of the barn. Good goop and nailed the tin on.
sell it!
Thanks but that won't' work right in this application. I would have to cut a channel or gutter leading to that drain.
It won't work, or you don't want to put in the work to make it work and cut into your rental profits?
I've used bentonite clay from the feed store to seal up more than a handful of basements/chimneys without any repeat offenders...its the same stuff that is used to cap wells. Craziest stuff you've ever witnessed...if you fill a container 1/2 full and then add water the top half inch will get wet, but it won't penetrate any deeper. All I've ever done is dig a trench next to the wall, maybe 6" wide and 10-12"deep, put 6-8" bentonite in the trench and cover it up. You might get water one more time but once it gets wet, it'll swell and seal. Cheap too, $20/50# bag here. Any way you could stuff some of this down between the asphalt and the building? Maybe blow the seam out with compressed air and fill it in?
I believe bentonite is used in dam applications as well.
FB, what are the chances you have some underlying contributors such as springs and bed rock that might inhibit or add to water permeability? I don’t know the address, but know that area has alot of changing soils.
