Anonymous-0
I have read a lot of comments about burning up your points. What do burnt points look like? Are they pitted? Are they black? Are they stuck together? What causes points to burn up? Thanks for your time.
(quoted from post at 08:10:21 06/17/08) Usually they will have pits on one side & raised areas on the others. Sometimes they just wear unevenly. They will most always discolor as they have a coating on the surface. The usual causes of burned points are condenser failure, a decreasing gap caused by wear on the rubbing block, mis-alignment, sanding w/ a point file, excessive current, setting an incorrect gap, leaving the ignition key on w/ the points closed & poor quality metal. I've heard of points being welded shut, but I've never seen it happen.
Buy good quality points & condenser, set the gap correctly w/ a clean feeler gauge, use the cam lube, make sure they align correctly, turn the key off & have correct current to the points. My last set in my 1950 frontmount lasted one month short of 4 years. And, if you ever use a point file, plan on replacing the points very soon afterwards.
50 Tips
(quoted from post at 11:09:19 06/17/08)
Someone was watching over us that day. What were the odds that someone would actually stop to help, let alone have exactly what was needed to fix the car??
[/i]
