grandpa Love
Saw this yesterday. Was told it was a chicken poop spreader. Anyone have info on it? Thanks.
Is it old? Who made it? Hopper on top is about 4 ft across
ya that should work good for a fertilizer spreader for small plots. have not seen one like that.
Yep,I'd say chicken poop spreader. Any pics of the inside? does it have an agitator,or an adjustable gate?
It is a small fertilizer spreader. It could be also used for broadcasting small grain or hay seed, but less likely. The window through which the granular material flows to the impeller is probably adjustable. I have never seen chicken manure that could ever be applied that way. Jim
forgot to say those broadcast wheels under the hopper are very much the same as the fertilizer spreaders nowadays.
Adjustable gate in bottom, once it's freed up. It's open wide.....about 7-8 inches square. I hope to go back and get it. Hope to spread composted horse manure and wood shavings.......
I would agree with Jim. It's a broadcast spreader and not real suitable for spreading manure unless it is very dry and fairly fine. Otherwise it will clog. There is no agitator in the hopper that I can see to keep material moving and not much of an incline to the hopper bottom so anything you put in it would need to be free flowing. That would be seed and fertilizer. Even lime I think would clump and stop coming out unless it was pelletized. I have used something similar to plant hayseed and spread fertilizer in small fields where bigger is NOT better.
With all the goofy weather you better get that for a salt spreader for the next ice storm.
Will not work well for spreading horse manure either. Will spread granular fertilizer well. Just use a regular manure spreader for the other things.
That is not old. That has Amish made wheels on it. If I am correct those wheels are made in Holmes county ohio. Heart of the Amish in Ohio.
(quoted from post at 09:53:02 02/02/20) With all the goofy weather you better get that for a salt spreader for the next ice storm.
That is exactly what I think it was intended for. Spreading salt and sand.
