What is it??
Dave Sherburne NY
I Think it is a Plow point ON the back the number is 82DS [ P ]
[ W ] that P is over the W and they are in the top and bottom of the H
LP
N4 Not sure of these
I believe it's a plow point also. Was just at the local ag store and a guy was buying a boxfull of something that looked just like these (don't know about the numbers).
Dave
I can't see real well but I'm 90% sure.
What you have is a plow point, but not as others have suggested from what I see. If you ever walked behind a walking plow and got into cutting roots around stumps you will understand this point. If you cut a root off with a walking plow it tears it apart and often a root will snap back and take your legs out from underneath you. Even a fast young man would be found laying on the ground rubbing his legs after such a ordeal. This device worked at the top of the cut and would cut the root so it would not spring back and take your legs out from under you. There are numerous ones in old machine sheds around here.
The reson I'm not 100% sure is I have never seen one with paint on it before.
North East IA
That looks for all the world to me like a point for a horse drawn two way walking plow. Can't identify the make but I've seen Oliver and Vulcans. They had a latch on the back that you tripped with your foot,rolled the bottom 90 degrees and went right back on the same furrow in the oposite direction.
