What is this tool?
Zachary Hoyt
This has been kicking around the shop for years and I cannot
imagine a use for it. Does anyone know its intended function? It's
about 6" long or so, made of some kind of masonite like material.
Thanks very much.
Zach
Sorry, here are pictures.
Zach
Yep sure is a fuse puller. For pulling fuses out of disconnect boxes on electrical services. Made of insulated material in case you really didn't have the power shut off when you pulled the fuse!
Thanks for the explanation. The fuses I've seen before were round and screwed in like a light bulb, except for the automotive ones. Are the fuses you describe still in common use or have they been replaced by circuit breakers now? Thanks a lot.
Zach
lots of fuses round north westen pa. that you would need that tool for. you can buy that tool in most any hardward store round here.
Still in use in industrial applications. Usually find them in the disconnect box at a machine protecting that machine. Fuses are a cartridge. Depending on their currecnt rating,some are as small as the barrel of a pen, some the size of your finger, others the size of a hot dog and some as big as a thermos bottle. Probably even bigger in very high current applications but that is the range of sizes i deal with. Makes quite the noise when the big ones blow!
Most Farm Grain Bin Electrical Service Panel set ups utilize boxes with Cartridge Fuses installed. Common set ups where I come from.The Tool described is used to remove Cartridge Fuses.
Those screw in fuses are also still in use in older homes built before the 50s. Made of glass with an element visable thru the top. Insurance companys don't like them because people will replace them with a slo-blow or higher amp fuse to eliminate a blown fuse problem instead of finding the reason they blow. Or they'll use a penny under a bad fuse to get power back. Both an unsafe situation.
