(quoted from post at 12:58:03 07/21/19) Fan on generator is contacting generator body.
Could be as simple as someone assembled it wrong and left a "shim" out or put it in the wrong place, or the generator front bearing could have failed.
Does there happen to be an old-fashioned auto-electric shop in your area that does generator and starter repairs?
If you happen to be that lucky, it might turn out to be a low $$ fix.
(quoted from post at 15:35:04 07/21/19) should be a simple no cost fix
(quoted from post at 21:51:54 08/02/19) [b:c045e40f0c][i:c045e40f0c]
Am I going crazy....OR, am I seeing where a fin OR MORE, of the fan is missing?????? I am seeing where ....I think a fin has broken off, and if that is true, the broken pieces, are probably what is seizing up the genny!!!!
I'm thinking you are going to need a NEW Genny fan, and possibly more to fix!!! Also buy a new fan belt while you are getting your other part/parts!!!!! The other belt is gonna need to be replaced!
Prob. burned smooth and shiny!
JMHO!!!!
GB[/i:c045e40f0c][/b:c045e40f0c]
