What model John Deere is this?
Dan J
This tractor is advertised for sale locally as a John Deere 40. With the dash I think it is a 420 or 30. Asking $3500 with new tires. Anyone know exactly what it is from the photo? Thanks, Dan
Looks like a JD 430 V or high crop. I would buy any 430 in that shape for $3500 unless there was a major issue with it.
chris5
lt looks like a 430-t with a wide front on it.If the seller advertises 40 you might look at the bell housing and see if its been changed or if this tractor indeed is a put together water with parts from several models.If its a 430 look for the water pump or the way the water pipe comes to the block which I cant really tell on the pic
It is a 430 T.only the T has that type front end.The front bracket holding the front axle is triangle shaped.Has 430 sheet metal and a 430 dash.Tooooo bad it is not a V !!!!
ive looked at tractor when this guy first bought it. he put rear tires on it its a 430t...had carb issues from sitting but its a nice tractor.
