hi folks
so i am hoping for suggestions here. i am stumped. this is a te20 with a z120 that had not run for at least 8 years but supposedly "it ran" and was set up with a scraper for winter driveway use.
when i got it the sump was full of gas mixed with oil and the carb was literally filled with grey dirty sediment. the rad had clean looking green coolant mix.
it has a fairly new looking 12 volt negative alternator fitted, and had the original 6 volt coil and starter with a ballast resistor. it had an ignition from a car that seems to work fine with power to the coil in the "on" position
i have
-soaked the cylinders in seafoam for several days before cranking. it appears to have decent compression although i have not tested.
-cleaned and rebuilt the carb with the basic napa kit and set the idle to 2 turns out, the power mix one turn out and the float to 1/4". after a lot of effort i am confident all the carb passages are clear of crud.
-replaced the corroded distributor cap with a new one, new rotor, replaced the plug wire leads, and installed a 12 volt coil (bypassing the ballast resistor)
-replaced the fuel line and the fuel bowl strainer/shut off
-soaked the gas tank for days in castrol super clean and gotten most of the crud out. i still get a little junk in the sediment.
-tried every combination of throttle and choke setting i can think of
it started the first time i tried and it ran for a couple of minutes at full throttle / no choke. the engine did not make any bad sounds but as soon as i backed off the throttle it stalled. after three days i have not been able to get it running for more than a couple of seconds since.
it will start for a second the first time then stall when you try to start it cold. i will also sometimes start for a second if you shut off fuel, drain the carb bowl and wait a minute.
it does not seem to be flooding and i have played with the float setting out to 5/16" to no avail. i have removed the carb and the bowls are about 2/3 full
the points look ok but i am ordering new points and condensor anyway since i can't think of what else.
i get a small white spark. not blue.
i do also have a couple of questions about the carb.
there is a single hole to the left of the idle jet hole in the upper body where the marvel schebler manual says some carbs have an economizer jet. there is nothing in that hole and i see no threads. it is a tsx361a carb according to the little brass plate. i assume it has no economizer jet.
also, the choke plate is missing the retaining spring for the little door and seems to be in backwards. i cannot remove it because i cannot turn it so that it faces the right way. it seems like it is machined that way. i cannot figure out how to remove it.
any help would be appreciated.
i have
