(quoted from post at 04:49:27 04/12/12) I think that is a wise choice really, as long as it will take out the wheel marks, it will be fine. But do keep the blades sharp as you can lose so much power if they are dull, plus it will make a much neater job of cutting, if the blades are dull it will "knock" the grass off, not cut it, and you will get a white appearance from the top part of the grass leaf, which will look awful around your house. I don't think that your better half would be too pleased with that.
The figure of 28.2hp is at the PTO.This is for the 85mm engine only, if you have the 80mm engine it will be 23.9. Do you have an Over-running Clutch fitted to the PTO shaft of the Mower, this is a necessity as you only have a single Clutch on your tractor. You should avoid lifting the mower too high or you may damage the joints in the PTO shaft, you may hear them rattling, this is telling you that they are under stress and they will eventually fail. You should only need to lift the mower clear of the ground to turn around, say about 12". You can do this with your tractor Hydraulics if you lift the mower and as it is lifting, move the Lever forward towards the Lower Position until it neither lifts nor lowers. When you reach this point, move the Lever stop up to the front of the Lever and lock it in place.While you are setting this have the Engine running only at a fast idle speed. All you do now is lift the mower and move the Lever to the Stop when you get it as high as you need it to clear the ground.Leave the PTO Running unless you wish to stop the Blades as that is also driving the Hydraulic Pump. If you have a need to transport the Mower a distance, then detach the PTO from the Tractor so that you can lift the Mower fully and leave the Hydraulics running, this will allow the hydraulics to keep the mower at a constant height automatically if they creep down. The correct speed for the PTO is 540rpm which is at 3/4 throttle on the Engine.You should avoid running it any faster.Email me if you have any questions about all this..John(UK)
[email protected]
