What tractor is this??
That is a good question. The serial number is for a 1250, the model number is not. If it is a1250 there are 2 adjustments one external, one internal. Can you post a picture of the tractor.
Here it goes
They kind of look like they might be. I wouldnt mind finding a tractor like that to cut hay with.
Yes that is true but first things first I have to find out what type tractor it is clutch needs adj it takes awhile to release an u have to almost b all the way off it for it to engage
Is there anything I can do to figure this out its . You don't think it's a 1250 anything I can do
To figure this out I'm trying to adj the clutch it's not very safe
I sent you an e-mail. I have some pointers that I did in article. If I had your e-mail I could send them to you. You will need to adjust the external adjustment first and then the internal adjustment. A couple simple tools and a feeler gauge. So did you get my e-mail or do I need to send it again tonight.
If it was a 3 cylinder it would be easy to tell. That power steering setup isn't a 1365.
