Wheel weight bolts
IH Guy
Can anybody tell me the length the wheel weight bolts are for the split weight for a 1256. I believe they are square head. Anybody have a good source?
Usually the parts catalog will answer hardware questions. I assume you are mounting split weights with 38" wheels. The book calls out two sizes, 3/4 x 4 and 3/4 x 3-1/4. I assume the first size is for the first set and the second size is for the second set of weights.
I just used threaded rod through the whole thing and slide them on the rods. I also stagger the ends just a bit so I can start them one or 2 at a time. A plank piece to roll them up on so I can start the weight on the rods. I also stagger the half weights so all 4 bolt/rods hold them. About 16-18 inches will hold 3inside and 3 outside. on my 806.
