Wheel Weights, What do they weigh?
I was wondering what the old two piece (split) weights weigh?
I would think they weigh around 200lb per half, because it's all i can do to stand up one half and tip it over into a loader bucket.
I just put a full set of these weights on the back of my little loader, and i was wondering how much weight i put on?
Thanks for any info
May well depend on what they came off of. I have a couple sets of them and if I had to take a guess each is around 75lbs each give or take a little bit and the full circle type around 150 each
These where off of a M, they half to weigh more then 70/75lbs per half, i can carry 2 50lb bags of feed easy, i can also carry the one piece farmall weights (120lbs) with out any issues and i can't get these weights no more then a few inches off the ground.
Here is a picture of what i have
(quoted from post at 20:09:54 12/13/12) I was wondering what the old two piece (split) weights weigh?
Thanks for any info
I have gotten some tractors out of Tx that had very heavy weights on them. They were double or maybe even triple what the usual split IH weight was. They also had the IH logo on them. Put a pic on here and we can tell you if you have a set of the Tx heavies.
There are two pictures added above, use "Modern View" to see them.
These weights are 5" thick, they where on a M, this is the 2nd set that i have gotten, the other set was on a M too.
They are NOT IH weights. They are definitely aftermarket.
Without seeing them from the side so you can read any lettering on them, there is no way to tell who made them.
Since you got them on two different tractors, presumably from the same area, they could have been cast by a local foundry.
