Paul in Edmonton
How do you know when it's time to rebuild an engine?
Is low oil pressure a key factor? Or is that just the oil pump?
My tractor has good pressure when it's cold, but gets lower than I'd like when it's hot.
Yesterday I was plowing snow for a couple hours in -22°C (-8°F) weather. At that temperature, I had to use my tiger torch to heat the oil pan enough to allow the engine to turn over at fast enough to start. (It'll start without preheat at -10°C but clearly not at -22!) It then had 30+ psi of pressure. A couple hours later, it was maybe 15 psi at idle and just over 20 at full throttle. In summer it will drop below 10 psi when it warms up.
Last time I checked compression, all four cylinders were somewhere around 100.
-Paul
-Paul
