Where does it go?
jbp
I have a 50+ year old tractor that had new rear tires and tubes, no fluid, put on three years ago,and no air needed since. My other tractors have calcium cloride in their tires and they need a shot of air now and then even though they have no visible leaks. My question is, where is the air disappearing to in the tires containing calcium cloride???? There are five with fluid and they require air occasionaly. Thanks,
Joe
I'll give it a guess. Liquid filled & non-liquid filled tires loose the same amount of air. It's just that non-liquid filled tires have way more volume of air in them, you don't notice the loss. Also, the air is compressed a lot more. Liquid doesn't compress. A non-liquid filled tire is maybe 30# of air. Liquid filled is half of that.
Or something that I discovered yesterday when I went to air up a soft loaded tire. The chloride had done a number on the valve core so that it wouldn't quite seal. Had to put a new one in it.
Whether you have fluid or not, the air pressure for the tire is the same. The fluid doesn't hold the tire up. It will take less volume of air with fluid but that's it. Dave
Ollie is right. The amount of air in a liquid-filled tire is less. So if you lose just a small amount of air (by volume or mass), it makes a bigger difference in the pressure. PV = nRT
Some tires seem to hold air forever, others slowly lose air. Fact of life. I remember when I was home on the farm every spring when equipment was gotten out of storage and tires were checked I remember one tire that went years withour adding air while others needed to be "topped off" at least every spring and sometimes throughout the season.
Areo
I took the # symbol to mean pounds as in PSI not volume in cubic ft. The PSI is the same whether filled or not. I don't know any rear tractor tires that take 30 PSI pressure. Usually in the 12 to 18 psi range. Radials even less. Dave
Been a long time since I monkeyed with tractor tires. But yes, seams like there was quite the difference in air preasure between loaded and unloaded tires. Now I'm talking about bringing the tire up till the bulge at the bottom of the tire just disappears. That's how we always run our tires. As far as air preasure goes, you're right. Air preasure is air preasure.
Air is not going to be continuously absorbed into the water over several days, let alone years.
It's impossible for a valve stem to hold back salt water. Use a high quality metal cap instead of a plastic valve stem cap. Leakage will be slowed.
