(quoted from post at 01:20:36 10/05/20) Then there is the grease guns every time you fill them you can't get the air out without letting them sit a while
(quoted from post at 07:29:42 10/05/20) When I put a new grease cartridge in I don't tighten the canister tube all the way at first. I pump it until grease starts coming out and then tighten. That should get the air out of it.
That's the way I do it too, works everytime.(quoted from post at 13:48:37 10/05/20) I've never had to spend more than a couple of minutes to get a grease gun pumping. You just pull that handle out on the bottom and twist it to lock it into the piston that pushes the grease to the gun head. Put the handle against something solid, like a tractor tire, or the ground, and push gently while pumping the gun.
hen I saw the thread title I couldn't wait to open it up and see where you're from when you call "customers" "gease". As far as grease guns go, I once had a gun that didn't want to work when I put in a new cartridge. Once. Threw it away and bought a new one. I have three in the barn right now that I've had a long time and have never had to do anything other than push the plunger rod all the way in and pumping a few times.(quoted from post at 23:04:21 10/04/20) We have cheap gease here too. Freeloading varmints squat around the local watering holes all summer leaving their deposits and then during harvest they panhandle the farm fields for freebies. The only upstanding gease are the ones Bruce sends down to visit Larry.
s it usually or never? Can't be both.(quoted from post at 15:09:44 10/06/20) I usually never have any problems but this tube has sat on its
side so long the grease is all in one side so the tube i don t
know if it ll ever go
ine's better than yours.(quoted from post at 11:02:43 10/07/20) Reading comprehension isn t your strong point is it
