mr.Q
orry my keybor i broke but i w jut wonering y o rmer pull there implement on ngle cro the iel n then plnt tright own the iel? wht r ome tilling trtegie?
"sorry my keyboard broke, but I was just wondering why some farmers pull their implement on angles through the fields and then plant straight down the field? What are some tilling strategies?"
somebody has to much time on their hands an not enough to do that said here is my version as a 62 yr old farmer.If you work your ground at an angle it helps level your field. When you plant you can see your marker better. Wildman good luck
oh, i definitely agree with seeing the marker better. I can't explain the relief it was to till sideways as I can see the marker about 500% better. I used to go with the ways, and My eyes would wander off to other ruts.
Tilling on an angle helps cut trash and level the field. Often what you see is certain crops like soybeans planted on an angle so that when you spray you dont knock down as many beans.
