Wico X help
ratnester
Trying to rebuild my Wico X for my JD H. I can not get the dog plate off. I have pulled the armature out and tried to gently pry it off with a screwdriver (see pic). I have also tried to drive the shaft out the front side while in the case with a rubber mallet. No luck, won't budget a bit. Any tips? Is it ok to use a little heat?
I'd try 2 pry bars (screw drivers ) 1 on each side and wiggle it up off of there ? I never had too
much trouble getting them up off of there.
