I can't find any details on start timing in the service manual (pertaining to a '48B), apart from a minimal mention of it (I have the JD 96000-and up B and the IT service manuals). There have been a few posts here about it, and I have Duane Larson's article. Nothing seems to have pictures or detail a starting point for the mag. inside ring setting, and it has to be removed to make any adjustments. I've already set the run timing to 25 deg. BTDC, and since doing so, the B starts really hard. Duane's article details a procedure, but he says it's for the Wico C and XH, which I don't have.
My Wico X has the 6274 cup, which is also stamped "25 degrees." Duane's article on mag timing states that the markings on the inner timing ring are worth 5 degrees apiece. Mine is set for two major divisions west of due north, a.k.a. four minor divisions. I do not know where the run timing was set before I changed it.
Is due north on the inside timing ring of the mag 0 degrees, TDC, subject to run timing advances? So in other words, if I want start timing at 0 degrees, TDC, do I need to set the start timing ring at -25 degrees to compensate for my run timing adjustments already made?
And as to specifics of the start timing ring, if you have the mag off and you're looking at the ring, is west advanced or retarded, relative to run timing (or relative to rotation, run timing aside)?
I know John T directed me to the manual on one recent post for details on start timing, but unless I've missed something, I have all the relevant manuals, and don't see anything detailing that setting.
