wico xb coil short
I put new points on my JD 50 wico xb, still no spark when I flick the points. there was an occasional spark at the spark plug after I cleaned the unit and reassembled it but that was with the old points. thats why i figuired new points would solve it, and that the coil was good. There is however with the new points, a small spark jumping from the side bar of the coil to the coil winding, both on the side and at the rear of the coil bar where the small slit is back to the coil winding. any idea why this would be. if i flick the point clear down to the shaft it arcks across the shaft, so there is power there. but still wont jump the points because it would rather jump at the coil. is this a grounding issue?
Thanks for your help
might try a new condenser. sounds like your trouble started with new point set, are they shorting out? what about your rotor and cap, what condition are the tip and posts in. does the high voltage coming out of coil have a good circert to follow to spark plugs? is the coil grounded good? just my thoughts. good luck, d. coleman
just reread your post. if it is a wisco distributor and you are "flicking the points", that means you have the cap off!! the high energy from coil has no place to travel, that may be the reason it is arking to ground. probley fried your coil insulation. John T is the man with alot of knowlage on eletrical matters. d. coleman
Andrew, I just cant understand exactly where that sparking/arcing is taking place and if its in the LV primary or HV Secondary BUT it may be the HV secondary side of the coil and if so its BADDDDDD and needs a new coil. That means the insulation is breaking down (under HV or temp, eitehr or both) and the HV is arcing to case versus getting out to the cap n plug wires etc
Just to make sure the condensor isnt shoretd out see if you can remove its lead off the points terminal n see if you get a spark (albeit weaker with no condensor) out the HV side??? If she fires good without the condensor lead wire attached TRY A NEW CONDENSOR.
There may be a poor connection in the LV primary/points circuit or perhaps either the coils ground or the points ground isnt good. I forget where n how the XB coils LV primary grounds but check it and the points terminal wiring and the physical points to case contact for all bright clean tight shiny connections.
Those XB's have an internal resistor on the inside of the plastic/phenolic mount where the input wiring stud is, its very low ohms (less then 1 ohm I believe) but if its open or bad theres no spark. But if it were open you would never get anything and that dont sound like your problem
If that arcing takes place AFTER the poinst ahve been close but then AFTER they are opened, it sounds like HV insulation breakdown i.e. a bad coil
Sorry I cant help much unless I were there but check the condensor and grounds and connections n see if thats a HV arc and if so get a new coil. Im fairly sure alllllllll XB's are for 6 volts so if on a 12 volt tractor there needs to be an external series voltage dropping (12 to 6) ballast resistor between the ign switch and XB input stud or else the coils can overheat and poinst burn up fast
John T
I replaced the wico XB with a wico X magneto and was tickled to pieces. That wico dist was always a big pain in my rear. Get ahold of Jack Chandler at www.magneeders.com and get a mag. My $.02
