Will a D17 make a good loader chore tractor???????
RickyP
The loader hyds is run off of the PTO and it stops everytime you push the clutch in. Just wondering what you all think. Ricky
If your power director is working good it should be ok. You would be better off finding a front mounted pump when you can though.
I used IHC H with same type setup - it's usable with a bit of forethought, no big deal. If you want live hydaulic on that particular tractor get a engine driven pump. Some threads in archives about mounting Char-Lynn units, some on truck powersteering pump mounting. RN
Have a loader on my 17, if ur not doing alot of frontend work its fine, the way it is.. The power dir. helps alot if its working properly...
We have a D17 and that's what we use it for and I would hate to think of being without it. Has been 26 years, BUT we have the 417 loader with a front mount pump. It's been a dandy.
Good Luck.
Use the hand clutch. Works for me. I only push the foot cluch when I need to change gears. I usually am not trying to lift when going from forward to reverse. Look for an I60 or I600. That's a D17 or D15? with shuttle transmission and heavy front axle..
A front mounted pump would make it an ideal tractor, used to drive one. Then we up-graded to a series 4 and it had a mid-mounted pump that worked better ! Dual wheel weights and loaded 18.4x28 even helped more. My 2 cents.
