Will this work on a ZAU??
Jerry Wallen
Will a generator delco remy # 1100029 also # 6661 work on a ZAU? My book calls for a #1101398 does anyone know the difference between the two? Thanks for your help Jerry
Jerry, I am unfamiliar with Delco part numbers, but if the generator is 6v, is similar to the original and has the correct mounts to fit your ZA, it should work.
I have an old I&T Standard units manual and it shows the original gen. to have a 35 amp output at 2650 rpm and the one you are asking about to only have a 11 to 13 amp output at 2000 rpm with also a higher field current draw of 2.6 to 2.9 amps vs. 1.85 to 2.03 amps. Possibly if you spun the generator up to the same speed it would put out more. You may still want to try it and see if it will produce enough to keep your battery charged.
Bryce
