winches and ROPS
Katharine
I have been searching for prices on a ROPS and for a winch to mount on the front of the tractor. Anybody know a good place?
http://www.extension.iastate.edu/Publications/PM1265D.pdf
http://www.herculesrops.com/index.php?Do=ContentView&pageno=282
http://www.saf-t-cab.com/faq.htm
Custom Products of Litchfield Inc.
Cabs and Rops
Box 718
Litchfield, MN 55355
Ph: (320) 693-3221 ~ Fax: (320) 693-7252
800cabline.com
Femco, Inc.
Cabs and Rops
500 North 81 By-Pass
McPherson, KS 67460
Ph: (620) 241-3513 ~ Fax: (620) 241-3532
femcomfg.com
Mahindra USA
Mahindra Tractor Cabs
17723 Fm 2920
Tomball, Texas 77375
Ph: 1-800-887-2286
mahindrausa.com
Sovema Canada Ltd.
Sovema Tractor Cabs
4845 Portage Ave
Headingley, MB, R4H 1C7
Ph: (204) 927-9042 ~ Fax: (204) 897-6975
sovemacanada.com
The Perry Company
Tractor Canopies
P.O. Box 7187
Waco, Texas 76714
Ph: (254) 756-2139
perry-co.com
Harbour Freight or similar companies for winches. If you need to haul 4000lbs, the winch size required will be "rated" at 8000lbs.
for a rops a dealer is the best place or talk to your local welder they can build a good one as cheap and probley better ,and as far as a winch for a tractor WARN now makes a brute of a winch that also has a built in air compresser which would be the handiest thing on a farm since you always have more flats tires than the need for the winch .and there again the local welder can build you a mounting bracket to adapt the winch to your tractor . google warn winchs
You would think, but my property is wet a LOT of the time (rains a LOT and water table is high)and I'm figuring it will get stuck a lot and I'll need to be able to winch myself out with a local Oak tree or my truck. Hence me wanting a ROPS, cause my two kids and I are the only ones around most all of the day. Don't want to be stuck under that dang thing with no one around!
Then you may also want to think about a tractor with front wheel assist and maybe larger tires to float it thru the wet spots as well . And buy yourself a nylon choker strap to tie to trees to prevent damage to the bark that can kill them
Don't listen to anybody that says either. You don't need a rops or other safety equipment " if you know how to work smart". Or tells that" you can build a better rops at home for less $$$".
Well, I have gotten lucky! I asked the gentleman from whom I am purchasing my tractor and he says he has one sitting on the side. It's never been involved in a crash, and since he has it, I'm having him install it. He wanted a $100 for it, so I took him up on it. $2800 for tractor, $150 for canopy to put it all under (rains a LOT here), $100. for roll bar, and about $300 for a good 5' bush-hog and he'll help me bring it all over. $3350 in total for everything.... Not bad, eh? Still waiting to get it all here though!!!!!!!
