Just a picture of my super A .I had a local canvas shop make this winter front it keeps the motor temp up and the carb from freezing .I also use blue stabil and dry gas, i havent any trouble with starting or runing and it is 6 volt,it works for me and the neighbors love it.
Very nice looking, and if does the job, thats all that really matters.
Is it just me, or did you add pieces to make that blade larger? Kind of looks like might have been a 48" blade at one time, now weighing in at maybe 60" wide plus some added heighth?
Mark
It's alcohol, you add it to the gas to keep the water from settling in low spots in the fuel system and freezing. You guys down south don't usually need it. This year could be different.
Yes it is 60 inch wide now , i do have weights and chains for it but i havent had to put them some day when i get time away from workin on our pullin tractor i will paint the ole girl
Why don't you spring for a seat cusion? Seams it makes the whole job warmer if you can keep the bottom end off the cold seat. Also in case you haven't noticed, the dog is chewing up one of your gloves.
Now ya done it! You better post pictures of that puller you're working on within 24 hours or you will be considered to have made illegal mods under the cover of deep snow.
Well u could check us out on facebook at silverfox tractor pullimg team or here is a picture this eas eaton ohio 2010 we were the highest placing michigan tractor in that class and took 4 th overall...
Yes, that looks like the mods are already done. It looks as good as it apparently pulls. You can see one of mine on you tube at Ford 9000 tractor pull.
