Wiring Diagram..
Goose
Would anyone happen to have a wiring diagram for an H Farmall AFTER it's been concerted to 12 volts with one on YT's conversion kits?
I have a kit, and want to convert an H, but the wiring is so bad I'd simply like to start from scratch., and the diagrams that came with the kit don't go into that much detail. Complicating it is this H has a loader on it with a hydraulic tilt bucket and all of the plumbing and hoses for the loader are riight where you need to work making the conversion.
I can jpull up all manner of diagrams online with various configurations, but none of them are what I'm looking for.
Which Alt. did you get. I just did on on a H from YT that fits under the hood with out cutting the hood
Has 2 wire connections. Battery power from Amp gauge or from the Battery to large stud and the other has to be powered when the Ing. is on. I went from the Battery side of the coil
You would have thought YT would have included the pigtail with diode to complete the kit, which would help you a lot. I am betting that the pigtail you need has the terminals in a "T" pattern?
