Wiring on a Ford 555B backhoe
culebrapr
I am rebuilding the harness on a Ford 555B backhoe but the wiring schematics I got from the Ford 550 Service Manual does not match the color codes on the 555B model. Therfore I am not sure what wires go where on the headlamps or starter switch. Does anyone have the correct schematic?
Here you go. You should be able to save the image and then zoom in to see what you need.
(quoted from post at 20:51:39 08/23/13) Here you go. You should be able to save the image and then zoom in to see what you need.
Thank you for the quick response. I saved the picture however when I print it it's too blurry to understand, could you maybe sent the file to my email address [email protected]
? Thanks again.
Early or late B?
They moved production into a new plant a year before switching to the C, and built the C as a B, using B cab/ROPS.
The late B and C uses this type of fuse.
