Hello CG welcome to YT! Here in the first link is
essentially what your wiring will need to look like if you
have a Delco 10si alternator less the ignition circuit. I
assume the 350D had the same ignition setup as the
gas we had that you turn on a key or switch and then a
push button to start. So in that case the diagram
shows the starter button powered all the time which it
is not. Also the diode shown can also be replaced with
a incandescent dash warning bulb wired in the circuit
like a resistor. On second thought you may not even
need a diode or bulb if you cut fuel buy a lever to the
pump. The diode/bulb is only to enable a spark ignition
engine to shut off and and not continue to run off the
power from the alternator excite circuit. The 2nd link
shows an example of a 10si alternator for visual
comparison. The 2 small wires plug in the side. If they
plug in the back you actually do have a 60s and early
70s Delco that requires an external regulator. The
regulator for those had a four or five plug to plug on
flat tabs on the regulator. The original generator
regulator would have screws to connect the wires. Be
careful on here using the word ..restore.. when you are
not keeping a machine 100 percent original, your
tractor would have originally had a generator. The
..correct police.. are mellowing out lately.
Wiring diagram
Example alternator
