won't Start
No, explosion happenes when you shut the ignition while driving and then after the rich mixture accumulates in the exhaust you turn the ignition back on.
Potato in the tailpipe has the same effect as a clogged catalytic converter. If the exhaust is clogged no air can leave the motor so no air can come in and you have no power.
Well I got the Tractor to run but when I engage the Finish blade it Cuts Off, did a tune-up put a New Starter on it because the Starter was bad had that tested , what could be the problem with it Now
l I took the Starter OFF And had it tested, it was bad it took me a minute to get it out cause it was Stuck on the Flywheel, Also I rebuild the carb Put New Plugs in and a New Choke Cable that wasn't working
I ordered some New Points and condenser, when they arrive I will Install them , but I did check And Set the old ones , trying everything before I go out and buy another Tractor, maybe I'll Service my1950 John Deere Tractor and Put in back in service it's been sitting about 10 years since I got the Ford
I started to enter a suggestion but then I went back to check something that you had posted earlier. Your observations and things that you have tried and plan to try are all over the map. Sorry.
