I am new to this forum and could use some help. I recently aquired a Yanmar 3000. I puchased a owner's manual from Hoye. However, the manual does not mention the lever located on the back of the tractor located next to the rockshaft. Yanmar dealer in my state was unsure on the lever's function. Does anyone know what it does? Also, I installed a temp gauge. Tractor runs at 150 degrees. Is this normal temp because it seems low? Finally, I picked up a factory style drawbar from my dealer. It has a 2" diameter shank. The mounting bracket under the tractor measures 2.5", and when using the hole that extends the bar out for proper position the bar is then only supported by one mounting bracket. I don't like the 3pt draw bars, and I like to stay with the frame mount drawbar. Is there a larger drawbar than what I have? The dealer said that the one I purchased from him was the largest he had seen.
