Yanmar YM2020D lever
Status
Not open for further replies.
Hello,
My Yanmar YM2020D have two levers at right of the seat.
Bigger (more right) for lift and drop three point hitch.
I dont know reason of smaler lever (more left).
I listen little about flexible top link (or something).
Can somone help or can share with link to read about it.
Thank You
Assuming you are talking about this lower lever. That is the draft control lever. The Yanmars equipped with it have linkage under the seat area that is made to accept a cable going back to a rotary tiller. Only person I know of that has it hooked up correctly is Mickey Fx. I'll try copying a thread about it. Not sure it will come over. May not be the lever you are talking about? <LINK_TEXT text="http://www.tractor.../105695-auto-tiller-controls.html</LINK_TEXT>
Most small tractors including Yanmars do not have draft control. Where they do have it, most owners never use it.
It controls the depth of rear implements that dig, usually a plow. If you're interested, an excellent explanation of how it works is on TractorSmart.com under "Tractor Three Point Lift Types."
<QUOTE author="alan"><s>
</s>Most small tractors including Yanmars do not have draft control. Where they do have it, most owners never use it.
It controls the depth of rear implements that dig, usually a plow. If you're interested, an excellent explanation of how it works is on TractorSmart.com under "Tractor Three Point Lift Types."<e>
/e></QUOTE>
The draft control talked about on "tractorsmart.com" is a different animal than the draft control on Yanmar tractors. The draft control on the Yanmars is strictly controlled by the linkage and cable hookup.
Status
