yard machine 14AJ84AH062
Anonymous-0
Sorry to keep bothering with these simple problems but this thing has died again. I was on level ground and it just died. Last time I replaced the Ignition switch and this seemed to solve my problem. Can I start the engine to see if it is the coil. I had a problem a couple of months ago and I replaced the diaphram, the PTO switch and the ignition switch, all seemed to solve problems at the time. I've noticed that it would briefly shut down on a hill and after shifting my weight it would continue to run. I disconnected the seat switch and still no luck. "HELP"
sounds like all the things you fixed weren"t the problem. A bad coil will act like that; quit when hot, start when cold. After you shut it down & replaced something, it got cold & easily started. No easy way to test a coil on the machine. Best way is to use another coil from a known good machine.
