Lou from Wi.
Up Mt Fujama and into the garage. J.d.here are some pictures of the crawler. Victor got it timed and loaded on the wrecker and up the drive under it's own power and into the garage. Took compression test on the cylinders ,as follows.#1 =100 psi, #3=110,#2=105 all held, No bleed down. 10 lbs oil pressure according to the guage.Cackles sweet.Still needs carb (slight) adjustment no miss or backfiring.Started right up after correct firing order was established.Let it run while on the wrecker to the house 1 mi from where it was sheded to the garage.Photos shows oil leakage at the rollers.some piece of steel looks like it was bent.(what ever it is)Throttle lever linkage is way out of adjustment and sticking. Left steering is out of adjustment. Gonna be a lot of work but FUN now that its here. Our profound thanks to you and all who helped to keep this old mans sanity by getting it to run at last,(after 5 years sitting). The previous owner helped a great deal with Heat & information on how it use to run.He put himself out by being there when we had to work on it.Swell fellow indeed.Now comes the interesting part, getting it back in shape. Gonna rest a while before we start. Need a break.Starting out the New Year right .Got the parts manual today. NO MURPHY"S LAW. Warmest reguards. LOU & VICTOR
