Yesterday in Alabama
grandpa Love
Too tired last night so here it is today. Made 4 big loaves of bread. Piddled around the green house and garden. Then after lunch raked our test field. Then greased and lubed the baler. And put a spot of weld on the worn out throttle levers from the Farmall A and M. They wouldn't stay in position. Easy fix. Spot of weld and a bit of bench grinder.
Untitled URL Link
Is that a 503 rake? I have one but have never seen another around here. I hate it but for $200 it's moved a lot of hay for me. Where's the stripper, it keeps the hay from flying over the back. On the other hand, when raking into the wind the hay wraps around it, have to go slow. I find for just turning over I run the left wheel just to the right of the windrow and in the opposite direction. That way it gives me a half turn and undoes some of the roping. Hint, if you find any with one broken tine replace them right away. If the second tine breaks off you'll lose the retaining clip and it's a dealer part. I could almost smell that bread.
