wayne c-HT
My YM1500 was doing fine pulling a 4' tiller though it would bog down when I hit hard spots and black smoke would come from the stack. After either rasing the tiller or just getting pas the spot there were sparks that came from the stack. Then it acted like it had a load on it when it did not and shut down. After it cooled down it cranked back up and was OK for about 10minutes and shut down again like it was pulling a heavy load but it was not. Then it would n ot crank back so I pulled it home with the truck. I tried but it would not crank that aftrernoon at all. Black smoke came out of the stack but it would not cdrank.
The next day I tried it again and though it was hard to crank it did crank and ran with no smoke from the exhaust altough there was a lot more smoke coming from the "blow by" tube and more oil than before. I shut it off changed the oil and cranked it agian but it only ran for a minute before it bogged down and quit running again. This last time there was alot of black smoke that came from the stack also.
What could be the issue or issues? Is there a good mechanic in the Georgia 30720 area code that I might get to look at it? Not sure about a diesel engine. Could it be the rings only?????
