knightstead
Three point stopped lifting on tractor so I decided to take my 135 diesel to the dealer. They said it was probably a bent linkage or bad control valve and estimated that it would be $300-500. Once there they found out the pump wasnt building pressure and asked if they could continue, I said yes. I get a call two days later saying the tractor is fixed and the control valve was bad, a $1,000 fix. Also put four new rings on hydrualic pump and gaskets. I didnt okay $1,000 worth of work and am very frustrated. Does this job normally cost this much? And also does the hydrualic pump need to be torn apart to replace the control valve? Any help is greatly appreciated. Thanks, Dan.
