by John Reeves
It was necessary to remove both rear wheels and axles in order to remove the differential gear - this proved to be difficult because it was impossible to remove the oil shute that transfers the lube oil from the gear case to the differential housing - I had to resort to using the cutting torch after drying out the interior . The oil chute is attached to the inside of the differential housing by two quarter inch cap screws - the screws are at the top of the housing and one screw is too close to the casting to attach any kind of wrench. At re-assembly this was modified by drilling a hole in the casing below the chute hole - welding a bracket below the repaired chute and attaching the the chute by means of one quarter inch bolt and lock nut , This makes it very accessible for both removal and replacement . Re-assembly of the tractor took approximately two weeks of off and on time - repairing broken studs - drilling and taping and a general clean up. Several knowledgeable people have commented that the MH 22 has a common fault in that the axles are prone to breakage .
I enjoyed working on this veteran tractor and discovering the simple but very effective engineering that was performed by Massey and Harris so many years ago.
We sell tractor parts! We have the parts you need to repair your tractor - the right parts. Our low prices and years of research make us your best choice when you need parts. Shop Online Today. Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V.
Yesterday's Tractors - Antique Tractor Headquarters |
