by Danny Bowes (Dsl)
If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development as the drawing board design itself. The engine, transmission, PTO units, steering, brakes--you name it--of a production farm tractor, all of these went through the trial and experimentation process. Right down to the hidden brackets holding the dash in place. Whether the part was made in-house, or secured from an outside supplier, it went through the trial process anyway, to make sure it was thoroughly compatible with it's companion parts. If a certain part cracked or fatigued due to a resonant frequency harmonious with part of the rotating or reciprocating mass of the drivetrain at a certain speed or RPM, the offending part/parts were tracked down and changed, modified, or even, in an extreme case, eliminated altogether, to correct the problem. Wear was detected, measured, and compensated for by alternate materials or metallurgical treatment processes. Tractors were abused on torturous test tracks to no end to expose hidden problems that would otherwise come back to haunt the manufacturer once the tractor began bouncing along in plowed fields. Severe 'test-to-failure' experiments unveiled problems that, if not otherwise detected, could have escaped the engineering department's attention, and led to expensive recalls, and retrofits. Occasionally, something would still slip through the experimental detection process, and cause major problems, much to the embarrassment and resultant damage to the reputation of the company concerned. This tended to happen more during times of rapid technological advancement, and the push to bring new merchandise to production to keep pace with the competition. Some new engines and powershift transmissions of the late 50's and early 60's fell prey to this reduction in development time. Failures and recalls abounded. One tractor in particular was so bad, that an exchange program was initiated the year following it's release, where the company gave the customer an entirely new tractor to mount the wheels and tires on from the returned one! This tractor was probably pushed by management through the development stage so fast it never was properly tested before it's release to the public. Largely to the company's subsequent regret, embarrassment, and expense. The experimental program of the development stage is there partly to avoid these humiliations. And to bring exciting new technological concepts into the light of day. The late fifties and early sixties was a time of great excitement and upheaval the world over. The Cold War was at it's anxious peak. North America was in love with the Kennedy's. Rock 'n roll was here to stay. The jet age was upon us, and everything else was trying to keep up. Automobiles sported fins, jet inspired hood ornaments, swept back mirrors, and wrap-around windshields, mimicking the aviation industry. Even missiles were imitated in hood ornaments and steering wheel centers. Yes, we were now not only in a jet age, but a NUCLEAR age. WWII had changed the world forever. Attempting to keep pace with the rapid change was the agricultural industry. The need for higher quality feed for faster gains and higher milk production was being addressed through biological experimentation and modernized forage harvesting systems. Mechanization was making inroads into feeding systems, also. Farms were becoming fewer and larger. Available farm power was being over-taxed, and the need for more power, speed, and efficiency (remember the jet age?) was distressingly apparent. Well padded from the post war demand for tractors and equipment, the farm equipment industry began to experiment in earnest in the early-to-mid 50's. The far-fetched experimental tractors the engineer's fertile imaginations conceived, and their talented hands assembled, were to change the agscape for all time. Many, many experimental tractors had been produced up until the time line of this article. Most were prototypes; the forerunner of an actual production unit. Some were tried and discarded as useless, unreliable, impractical, too expensive, or so far advanced that they would not be accepted by the consuming public upon release. That was the fiasco that befell the before its time 1938 Minneapolis Moline Comforttractor project, and no agricultural equipment manufacturer wanted a repeat of that. The remainder of this subject is dedicated to those experimentals that, even built 4 decades ago, still encompassed some such radical technology that it is nearly too much for the public to grasp yet today.
1957 Ford Typhoon
The Typhoon's radical free piston turbine engine
80 horsepower in a 90 pound package!
The tractor's sleek, high visibility body work consisted of molded fiberglass panels. Obviously a lightweight unit, wheel weights are apparent at both ends to better utilize the capability of this little powerhouse. This tractor was displayed for the first time publicly at the 1961 Tractor Day at the University of Nebraska. It is now in the Smithsonian Institution in Washington. Although nothing tangible came of the turbine technology, which was deemed to lack enough fuel economy for practical application, the hydrostatic transmission technology was to appear in production in 1967 in the IH/Farmall 656 Hydro, and after, in other models of the line. High visibility body work, consisting mainly of a steeply sloped hood, has only in recent years begun to show up in new farm tractors.
Departing from the lightweight 80 horsepower IH HT 340 above, this 20 horsepower tractor weighed 5270 pounds, and certainly required no supplementary weight. Here was power of a completely different type. The AC fuel cell tractor used an AC D-12 tractor chassis loaded with 1008 individual fuel cells, fueled by a mixture of gasses, but predominantly propane, which in turn created a current flow. This was channeled through to an Allis Chalmers 20 hp DC electric motor to propel the tractor. Each fuel cell was about one quarter of an inch thick, 12 inches square, and produced approximately one volt of output. In unison, the 1008 fuel cells made an output of about 15KW.
Unconventional, to say the least!
The XO-121's fuel efficient power plant
Outlandish as some of these experimental tractors may seem, the fact that your current tractor may not be turbine or fuel cell powered doesnt mean that some of the research that went along with these units hasnt made its way into it. So much for looking back, now let's look ahead; for the sixty-four thousand dollar question: what does the FUTURE hold in store?
We sell tractor parts!
We have the parts you need to repair your tractor - the right parts. Our low prices and years of research make us your best choice when you need parts.
Shop Online Today.
Yesterday's Tractors - Antique Tractor Headquarters |
