History of the Nuffield Tractor: Conclusion In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. The two new tractors had improvements to the engines and had hydraulic depth control together with independent hydraulics a new simms injector was fitted with a mechanical governor. The 4/60 and 3/42 were built at the Morris-Motors factory, Ward end Birmingham, England. Production was later transferred to the B.M.C factory at Bathgate, Scotland. The Bathgate factory was established in 1961 on about 250 acres of land, just outside Edinburgh. The training center for dealers and service engineers was sited opposite the factory at Mosside Farm, this measured 166 acres. It may be of interest to note that all the pictures for the sales brochures for nuffield tractors show photographs of machines in a farm environment. Either at work plowing etc or in rural settings. This is due to all machines being photographed in situ at Mosside Farm. In August 1964, the 4/60 and 3/42 were replaced by the 10/60 and the 10/42. The main difference here being the new gearbox which offered ten forward gears and two reverse, as opposed to the old 5 forward 1 reverse. These speeds were obtained as a result of a high / low range gear system operated by two levers. The high and low situated on the left hand side of the gear box. The side pully was dropped in favor of a rear mounted pully, the hydraulic lift was strengthened and the instrument panel redesigned to incorporate a rev counter. "Self energizing" disc brakes were also introduced as a new feature on the ten. December 1st 1965 saw "MINI" mechanization day. Nuffield tractors introduced their new "Mini" following five years of research and experimentation. The tractor was not well received, it was introduced at a time when tractors were getting larger and in fact the ten was by now classed as small. The Mini measured a mere 8ft 2.25 inches long and 3ft. 8.5 inches from the ground to the bonnet top, it weighed in at 2,098 lbs. A large amount of the development was done by "Harry Ferguson Research" of coventry (this may have accounted for the great similarity with the early T.E 20 of the 50's). It was offered with either a BMC 950cc petrol or diesel engine and put out a mere 15 bhp. The gearbox was a three reverse nine forward gears, via a high/ medium/ low/ reverse gear lever and a 1st 2nd 3rd gear lever which had a safety start feature. Due to poor sales, by November 1968 the BMC Mini was changed. A larger engine (BMC 1.5L) was added giving an extra 10 bhp at 2,000 rpm and the name was changed. The new Mini became known as the Nuffield 4/24, it became distinguishable by the poppy orange coach work with white wheels. In July 1967 the Nuffield 4/65 and 3/45 tractors replaced the 10/60 and 10/42 models. The new tractors were quickly criticized by farmer, and the press who disliked the new styling as opposed to the old Universal style. The new gearbox had two levers (side by side) giving 2 reverse and 10 forward speeds, the engine was again improved but suffered many faults, engine vibration being the most annoying. The hydraulic linkage was also updated, a pick up hook was available and the new 16 gallon fuel tank was placed at the front of the machine. The wheel base was also extended to a total length of 80 inches. Shell type mudguards went and full "square type" were brought in. The steering drag link bar was incorporated inside the engine frame, the hydraulic levers were changed and mounted in a quadrant on the right hand side of the driver together with the depth control lever as similar with other makes. The instrument panel was set just below the steering wheel and a hand throttle was added on the left side below the wheel. Regardless of all the "improvements" the machine soon acquired the tag of being unreliable which ultimately began the decline in confidence in the Nuffield brand. The B.M.C (British Motor Company) had been bought out by "British Leyland" by 1968, but at the royal show Leyland promised to keep the "Nuffield Tractor" line and disclosed plans to consolidate and expand it. After a year of designing and testing, rumors of a new " big" Nuffield tractor started to filter out of the Bathgate factory. In November 1969 three new machines were unveiled, however the Nuffield name along with the poppy orange and white livery had been dropped. The name had changed too, the tractors were now labeled "Leyland" (Nuffield) although the Nuffield was relegated to being a small sticker above the model number. Even this was to disappear the following year.
The Leyland 154 was the same as the Nuffield 4/25 apart from the change in color and three bars added to the front grill. In 1969 the retail price of the 384 De-lux was £1,186. The 344 De-lux £1,080 and the 154 De-lux was £680. The 384 model number stands for a 3.8 litre engine of four cylinders, the 344 3.4 litre engine with four cylinders and the 154 for a 1.5 litre four cylinder all of which remained unchanged until 1979 when production ceased. The old Nuffield tractor was still recognizable even in the new Leylands and in fact the Marshall tractors owe a lot to the original Nuffield tractor of 40 years ago. Leyland Tractors were eventually sold off to the "Marshall and Sons" and company of Gainsborough, England in 1981 when the "Leyland" name was dropped in favor of "Marshall" who still held some semblance of stability and a name for reliability and quality. Something which the Leyland group had lost and never recovered due to the economic troubles brought on in the 70's following all the union strikes. That concludes the history of Nuffield tractors in laymen's terms and I hope that the information in this article may be of use and interest to the owners of the Nuffield Tractor world wide.
We sell tractor parts! We have the parts you need to repair your tractor - the right parts. Our low prices and years of research make us your best choice when you need parts. Shop Online Today. Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V.
Yesterday's Tractors - Antique Tractor Headquarters |
