1/2 npt pipe plug what size drill bit???????
BUDD
I need to install a 1/2 npt pipe plug into cast aluminum. What size drill bit do I need to use?
Thanks for the help
BUDD
The outside diameter of a 1/2" pipe plug is .840"
a 7/8 drill will be.875" in diameter. There's probably fractional drills that will be closer to the .840". Hal
well for 1/2-14 the size would be a 45/64 drill or size .703 as you are using dissimilar metals make sure you use some anti-sieze on those threads as well. will help in dissasembly later on if needed.
checked another site and it said use the 23/32 I don't know that it would matter much as you have a plus or minus with a gauge because of the taper. in other wise it depends on how deep you tap it. deeper makes the threads bigger the more shallow you tap makes a smaller hole.
Be sure to use a tool to taper the start of the hole to get threads straight and it sure will help starting the tap. I have a 60deg tool in the drill press does great.
If you want to be precise, the 23/32 would probably be the way to go. But, you CAN get by with a 3/8 drill bit. I've done it. 3/8 would be 24/32, which is only 1/32 of an inch larger. A pipe tap is tapered, which means that the tap gets larger as you screw it in the hole. So, you have to screw it in just a little deeper, when cutting the threads. So, the question is, how precise does this have to be?
