Hello, I have an 1175 that has some issues with the pto. I tried using it for the first time and it did not have power to keep in turning when I hit thick grass. After I got it home I determined that the cable adjustment was way off and not moving the spool valve nearly enough. I hooked in a gauge and dead ended the line from the flow divider. At idle I have about 165 psi and at 1500 rpm or pto speed I have 195 psi which is about right according to the book. I need another fitting to be able to see if it holds that pressure with the pto hooked up. The brake that keeps the pto from turning seems to be worn because sometimes it will stop other times not. If I turn it off then back on it will using stay off until I engage the pto. If I pull it apart to fix the brake should I replace all the wear items while I am in there? What all does that consist of?
