Erik Finch
I need an operators manual, and could use bean plates and corn plates if anyone knows of some, thanks, Erik
Mike. Any chance you remember what the sprocket set up was?Erik, if you can't find bean plates you can use corn plates to plant beans. Use a medium round corn plate and it will drop two beans per cell instead of one corn kernel. Set the planter for the population you want (you will double what the chart says) and you will have a pretty accurate metering device. I did this years ago and it worked fine. I used a plastic B1 plate. Hope this helps. Mike
I own a plate 1240 planter. I kept it after buying my 7000 as a back up as on mine I can convert to narrow rows by moving the wheel brackets if I wanted to. The JD steel plates I have say H1555 on them I don't know what the plastic number would be. If I remember right there are 3 different size bean plates. Sorry but my owners manual was loaned out and hasn't been returned. They are a good planter.I need an operators manual, and could use bean plates and corn plates if anyone knows of some, thanks, Erik
