I removed the loader frame from my 1841 so I can replace the engine.
When I took the last side off, the tractor started to fold like a pocket knife.
Right where the bolster and engine meet.
Once I got a jack and some cribbing under it I took the front end off.
There were no bolts or studs in the right side.
Apparently it was ran that way for a while.
The stud pictured in front of the hole in the block was the only
thing holding the bolster on other than the loader frame.
It had a bushing on it.
That bushing is worn too badly to get a good measurement.
Even the ends are different sizes.
I haven't found them in the parts book or on the CNH site.
Does anyone know the part number and/or source where I could buy them?
If not, maybe the original dimensions? The stud is 5/8 so that's
no secret. The length would be easy enough to figure out too.
It's the O.D. I'm not sure about. Measuring the holes in the
bolster would get me close. If they aren't wore out too.
What are the thoughts on drilling larger holes and making
bushings to fit the new holes? Would it weaken the bolster too much?
There are only two bolt holes in it to connect it to the engine.
One on each side.
One on each side.
